- Sep 16, 2003
- Knoxville, TN
Yes. During my first Prime run using v1.30 I used 1x HTT. It booted and primed without issue.Zebbo said:Do anyone have experience about 2.5x HT Frequency or lower? Have you got it working or not?
tacobell said:As Zebbo said, I´m having problems with HT multiplier below 3x, anything below that it won´t post, max fsb here 335x7. Need 2.5x multiplier to go higher
Reefa_Madness said:You might want to consider updating the first post to add that there is a modded BIOS (Trats). I believe that it is available on the page that you linked for the beta BIOS, as well as in a seperate thread in this section of the Forum.
Zebbo said:I've tested out and noticed that half multipliers on HT Frequency has some issues to work, so try 2x instead of 2.5x and you should be good to go.
flawlssdistortn said:Just wanted to let you guys know about this issue that is being investigated regarding the mobo...
http://www.sudhian.com/showdocs.cfm?aid=616
If it turns out to be legit, you should include it in your guide.
