storm-chaser
Disabled
- Sep 2, 2011
- Upstate NY
I would like to get this system stable at 3.5Ghz, or higher if you think its possible with air cooling. Hyper 212+ (push, pull) and one additional 120mm fan in front, @ 3.5 cpu temps are ~35*C at idle and 53*C under load. Specs:
MSI-P43-C51 Mainboard
MEM: G.skill RipJaws F3-12800CL7-4GBRH (4GB x 2)
CPU: Q9550 (EO)
SSD: OCZ Vertex II 60GB
PSU: 600W Antec
Cooler: Hyper 212+
Case: Coolermaster Sileo (silent case, lined with sound deadening material)
I have been running the system at a standard 400mhz FSB x 8.5 for 3400mhz, and it has been rock solid in this configuration. However, I am now trying for 3.5. I bumped the FSB up to 412. Voltages below:
CPU: 1.254v (is this too high?, what should I be at for this clock speed?)
NB: 1.22
FSB VTT: 1.30
RAM: 1.63v (XMP profile - 7-8-7-20)
Prime fails after 5 minutes (though temps stay in range), and system randomly reboots after a few minutes. I have tried setting the memory to 1333, and issue still persists, so I think it comes down to my front side bus and/or FSB VTT configuration. I will post up a pic of additional voltages so you guys can see exactly whats what. Any help would be appreciated. Thanks! Of you guys think I can get more out of this proc, like 3.6 or 3.7 I am all ears.
CPU: Q9550 (EO)
PSU: 600W Antec
Cooler: Hyper 212+
NB: 1.22
FSB VTT: 1.30
