- Dec 7, 2004
Finally we had some nice weather, too bad i worked til it was almost dark outside=) butttt i started my no named project(for now) All i got done tonight was sanding my side panel thats behind the mobo. Pics will be posted at the end, starting case is a thermaltake xaserv wingo v7000, my plans are to sand it all down, paint it a metallic blue with metal flakes in it, get rid of the front door, bondo the front so that it looks like the door wasnt supposed to do there, bondo in the fron fan grills that are in the plastic(or get ridda them put a 120 there and mold bondo to make it look nice) Depending on how much more air flow i need with my wcing in to cool ram and HD. Also gonna add a side window. and paint the inside of the case either a darker blue, silver, or maybe a flat black. Ok for now thats it heres the 2 pics i got, before and after sanding the panel, lemme know how it looks, i did it all with a 150 grit sandpaper i might go over it with a 220 before i paint, gonna use 600 between coats of paint beings this is the highest grit we sell at my job.
Before Sanding
After
Before Sanding
After
