This was my first "custom" water cooled setup, my other 2 systems were kits one being the Zalman Reserator1+.
I will update with pictures later tonight.
Items I used...
Danger Den RBX Cpu Block
CoolingWorks CoolRad-22T Dual 120mm Radiator
Quiet One 300gph pump, 6.1 ft
Typhoon Dual Bay Floppy Res
ClearFlex 1/2" ID, 5/8" OD
2, aspire 77CFM 120mm fans
Temps are at 26C Idle, 34C Load
P4, 651 @ 3.4ghz
Asus P5WD2
1GB of Corsair DDR2 PC4300
Sapphire X800GTO 512DDR2
160GB HDD
550watt PSU
Some Mid Tower case.
Tubing and Coolent
Pump
CPU, P4 651
Case
Motherboard inside case
Danger Den RBX mounted on Motherboard
Items I used...
P4, 651 @ 3.4ghz
Asus P5WD2
160GB HDD
550watt PSU
Tubing and Coolent
Pump
CPU, P4 651
Case
