I have the following
420 watt power supply
8RDA+
Kingston hyperx 3500 ram
geforce 4 4200
1700+ (180fsb) at 1.675v
I can run my memory at or over 200 real easy. I can run my fsb at or over 200 real easy. I can not run both at 200 at all. I can not even boot at 195mhz. I ordered some corsair ram and then sent it back because the kingston worked slightly better. I removed the nb and put arctic silver on it. I have not cooled anything else. When I try to boot into windows at 195 it just neve makes it.
One would think that the cooling issue on the nb would still be an issue if the memory was running at 160 and the board at 200. I can not run the memory higher than 160 if the board is at 200 and get into windows. Could this problem be that the board is just not getting enough voltage to do the ram and the board at that speed? I hate to mess up my board with a vdd mod. I have never soldered anything before. Also did the arctic silver on the nb void my warranty anyway? Thanks!
8RDA+
geforce 4 4200
