AvionicMechanic
- Jul 26, 2017
- Louisiana
Hello Everyone! So my rig info should be listed under my info but if not I will post it on here.
So my question right now is, Which Temp Should I Go by?
I'm at 4.5Ghz with a Hyper 212+ and TWO Aftermarket 120mm 2500RPM Fans and It could be getting Hot?
Look at the Screenshot, and someone can possibly tell me what temp to-go by?
There is three temps referenced to the CPU below. I am using HWINFO64
CPU (Tctl) Temp: 35.4c MAX
CPU Package (TSI) Temp: 84.4c MAX
& under the Gigabyte Section of HWINFO64
CPU Temp: 48c MAX
Which one this is puzzling me very much??? Please help!
CPU Temp: 48c MAX
