- Mar 20, 2003
Hi, i dismantled my wc system yesterday and got a new idea
Here are my plans. After getting the Aluminum fans, i was like i cant hear! So recently i've decided that i want the high overclocks with low noise, and believe that i have found how to do it. My idea is this:
pump --> 1976 Chevy Impala Heatercore --> Swiftech MCW5002-A --> Asetek Radiator --> Tline --> pump
I'm testing it right now and its pretty good. Temps are hovering around 111 degrees F. I might have put on too much AS5, but whatever
[size=+1]Big plans for the Asetek Radiator[/size]
on the Asetek RAD, i plan on having two of these which should allow enough air to pass through the rad and still be quiet. Since i have two rads, i dont need such powerful fans on each rad
it also looks great!
This is what the rad looks like
mine is just a little bit more beat up, but still working. Its somewhat restrictive, but not much as i origionally thought. Then i came up to the conclusion that the rad was bad, i also had three elbows in my loop which kills performance
[size=+1] Mosfet Cooling[/size]
currenty, my mosfets are cooled by a TT 60 MM 30 CFM fan which is really loud. I'm thinking about getting a Smart Fan 2 which should be much quieter and cool a larger area. I can also easily connect it to a spare fan controller port on my TWY480 viewer (i gave the other fan to my sister )
[size=+1]Focus[/size]
the real goal is to make a pc that puts off some noise, but doenst sound like a vaccume cleaner. The sucess of this "mission" will depend on various fan controllers and how well i plan everything out. I'm used to doing a shady job on my "mods" but this might be the first one that turns out really well!
the Astek rad is capable of dissipating up to 400 watts of heat. The Heatercore can do more then 400 watts to temps should be relativly low
[size=+1]Post comments here[/size]
