- Dec 1, 2007
- Near Toronto Canada
Look in your mobo manual. It will give a layout of the front panel connector. The LED's are marked + and - so that's hard to screw up. For the others just put them in with the writing facing out.
You can also use the IMG tag inside [] and [/] to post images you have on photobucket, flickr, etc.
I just use MS paint to crop stuff. Run P95 for a while or AIDA 64, keep hwmonitor open, press PRNTSCRN on your keyboard, hit MS paint, paste, crop, and post.
PS if you have a Haswell chip (I don't remember, thread too long) do not use the latest P95. Use 27.7 or something like that. The latest version overheats Haswell.
Please don't use outside hosts. People on this forum sometimes browse from work and cannot see third party hosts.
As far as I'm concerned you shouldn't be screwing around like that at work anyways. Use the forum on your own time. America/Canada have a worker efficiency problem already.
Who says you can't use your work computer on break? Or on lunch? Just because someone posts from work doesn't mean they're slacking off.
I wasn't trying to use two outputs at the same time. I tried each separately. Neither every displayed anything. Also, the motherboard has a debug code that it is supposed to display, but that isn't lighting up, so it isn't helping me figure out what is wrong.
I got the Corsair CX750. I know it might be overkill, but it wasn't much higher than the cost of the 600, and I'd rather play it safe.
Howmuch? And is it gold, silver or bronze certified?its ok cx 750 is still pretty cheap
