SpykeJuggalo
- Mar 29, 2016
So this is my first time water cooling a pc, other then a pre assembled cpu block & radiator. My main concern at the moment is my pump position / flow direction. As you can see in the picture attached even in the haf 932 I'm running out of space. Id like to mount the pump directly under the reservoir, kinda in the spot its sitting, problem is I want it to sit facing out like it is, but then it pushes up into the res, and my fill & loop will connect to the top of the reservoir.
Is this ok? Ive read it doesn't matter about flow order, or position much, but I have concerns with the pump going into the res & against my fill, and the reservoir will need to be filled up all the way to push up. Id like to not have to get 90s for both in & out on the pump
