- Jan 11, 2011
- Montana - USA
My good friend and I were talking on the phone recently when he inquired as to whether I could build a mac mini clone. Not a "hackintosh" mind you, sticking with Windows 7 as an OS. Though the intel version, when it finally works (more on that later), could easily be used as the basis for one.
I also happened to want a computer that I could UPS to my mom and her husband without much worry. I also wanted it to be portable and could be used on their big screen HDTV. It was going to be AMD based to keep it as inexpensive (not cheap) as possible.
I would show off great pictures of the intel based one smashing benchmarks, complete with wattage and º info, but after my first reboot, the Zotac board went belly up. I'm in the process of getting in touch with their RMA department.
The good news, is that my AMD-based clone of the clone, so to speak, is up and running, though I am looking at replacing the stock cooler with a good quality low profile one. The clearance needs to be ~40mm to be used in this small of a case. In the meantime, I'm going to hook up a 40mm fan to blow air into the case to see if that keeps temps down. This is a Zotac AM3 board, but seems to be doing fine 20 minutes into Prime95. I never even got that far with the intel-based one, though I do have a picture of the limited info I got before rebooting.
I'm looking forward to doing more with the intel-based once I get a replacement, as the wattage was really low and the chipset fan helped keep the whole unit much cooler than the AMD-one that only has the CPU cooler at the moment.
Will update as I continue on...
Intel running at stock, Windows Experience Index running.
Intel - everything but the Pico Power Supply/SSD installed.
Compared to CD.
AMD version transferring a large video over Wi-Fi
AMD VersionI also happened to want a computer that I could UPS to my mom and her husband without much worry. I also wanted it to be portable and could be used on their big screen HDTV. It was going to be AMD based to keep it as inexpensive (not cheap) as possible.
Compared to CD.
Zotac WIFI AMD 880G SB850
AMD Athlon X4 610e 45w TDP
8GB DDR1333 Corsair RAM
64GB Crucial M4 SSD
Pico PSU - 120w
M350 case
Currently running the AMD unit through the gauntlet...
