Your ram discussion has definitely cleared up a lot of my questions that I've always had about memory, haha. Thanks guys.
And sorry about the late reply, I ended up getting busy yesterday. Although, I was able to try out my computer and check on everything. Fortunately, everything seems to be working great. Haven't had a single freeze since I corrected my memory settings. =D
And also, I've learned that the Rocketdock I'm using to launch all my programs, folders, and files is part of the problem, not with the freezes but the program response time when launching docked items. On their website, they note that Windows 64 bit is not yet supported. Even though I have it installed and it works fine, that is the only reason I can think of why it would load docked items with a delay. Because anything I launch from start and from old fashioned shortcuts is lightning quick, no delay for splash screen or anything like that. What you think?
Another part of the problem I believe or I should say I agree with you guys about is my storage HDD, it is a WD Velociraptor 300GB 10000RPM but is very very old. I agree with this limiting some things not just because it's old though, but because I have my computer set up with a 3rd party theme and all 3rd party icons which are stored on my HDD. I'm sure I have other files that are used by my OS which are stored on my HDD too. This would probably limit file browsing wouldn't it? Especially if my OS has to load every icon from my HDD which is slower than my SSD? The icon files are essentially part of the OS now.
I'm sure it sounds ridiculous to some of you, lol. But everything is displayed beautifully this and keeps my files still organized. Haha If you guys agree that's it limits file browsing though, I'll definitely be moving out all dependent files from my HDD to my SSD.
Last question. Do you guys suggest I Dban my HDD? Because I never bought this new and I don't know what's on there. I only ask because you guys were leaning towards malware earlier from page 1.
EDIT: I just noticed the Thanks button, I'll have to go through and thank all you guys for your help! =D
