- May 22, 2011
- USA
This project is epic in gargantuan proportions. Props again to Mister Diggrr.
Hence putting the loop underground.
Dig down a few feet and you have 55-65f just about anywhere year round.
This is absolutely true in some areas. I live on what's known as "black gumbo" which stretches across most of North Texas, east to west from Louisiana, and it's over 100 miles from north to south. Digging in this stuff is like digging in concrete when it's dry, and think of it as wet clay the rest of the time. I've given the project some thought as the office is perfectly positioned for it but I can't talk myself into that much exhaustion.
Diggrr hasn't been online since last year sometime, so I sent him a PM and he should get an email. I know he'll be back eventually, he's been here since the beginning of time, so hopefully once he gets back around he can give us an update.
Why not normal pvc or pex for the tubing?
{raises hand from the crypt}
Thanks Guys!
As Boulard and IMOG said, pex would work fine at far greater lengths, but I really didn't want to dig an 80' trench in my clay soil...20' was work enough!
Originally, I did want to go vertical, but at the time I was unemployed and couldn't fork up the cash for a post hole digger and 4 augers from the hardware here.
You can do vertical, but you still have to wash the dirt back into the hole with a hose, and that might take a few days to do.
That's the secret to not collapsing the soft copper...when you wash the dirt back in with a flood of water, it's already settled, so there's no shifting over time. I would zip tie the coils to vertical wood pieces though to make sure the washing process didn't hurt (it's hard to avoid clumps from falling in the hole with clay rich soil).
And now the update: Old man winter found the gap in the spray foam insulation before I did, and froze the line. No damage, but that also meant that once I got it circulating again, with the mean cold came line condensation that I didn't want to risk in my case. I had gotten a running CPU temp as low as 17° before switching back to my trusty Swifty triple (with new Gentle Typhoon 1450's).
It's actually quieter now that the pumps aren't pushing all that tubing too.
In retrospect, I should have gone with all 1/2" tubing, but between you and me, I can be a stubborn tool sometimes.
If I had my druthers, I'd bury it deeper, and come in through the basement/crawlspace wall rather than having any part of the system exposed like I chose (at least North of Tennessee).
A dirty project for this summer I suppose...
Thanks again for the kind words!!
Been chasing tail .vs chasing temps, before I'm old enough to join "ourtime.com"...
