Orka said:The Byter:
Looks very nice. Cables and tubes are organized very well.
1) What kind of radiator do you use? Are there shrouds attached to it?
2) What pump do you use? Is it eheim 1048?
3) What kind of liquid do you use? For how long does this sytem run and was there any bacteria growth?
Orka said:1) shrouds: http://www.overclockers.com/tips1022/
2) when you switched from 1250 to 1046 how did this effect the perfromance of the system?
3) you run it 100% car cooling liquid or mix it with distilled water?
Orka said:
the 1046 gave the same numbers, teh 1250 got hot and made my whole desk vibrate...
Thanks. That's very important to me as i'm going to run quite a similar WC in the near future. Why do you think 1250 heated up and vibrated that much?
3) What about liquid? Do you mix it with distilled water? Have you tried to run 100% distilled water on this system and was the performance if you did?
4) I notice your ICH (SB) has passive cooling. How did you attach it? Thermal glue?
5) Which fan sucks the air into the case and which blows away? Why so? Did you try different fan blowing directions and what were the results?
6) What was modded in PS besides the lighting on the fan?
The Byter said:
- all the fans suck air from the case to the outside.
Giblet Plus! said:
All the fans? Or just the ones on the radiator?
