My bad
All that heat coming out of my radiator must be my imagination. But if it isn't, I sure don't want all that heat traveling into the cpu first.Maviryk said:Your logic is partially flawed. Water loops should be designed so that it uses the least amount of tubing possible for maximum flowrate. The only time order matters is that the Res/T-line needs to be place before the intake of the pump so that it can be primed.
The difference between the water entering the rad and exiting the rad and entering is only about .1C max. Any more than than you've got flowrate issues. It's more important that the waterblock gets the maximum flowrate possible in order to induce turbulence inside the waterblock so that more water come in contact with the copper and carries away the heat. Better flowrate also has the same effect inside a radiator.
