- Oct 11, 2005
- Tau'ri
- Thread Starter
- #61
Cool thanks for your suggestions. I did somethin which is probably not recommended but sacrificed a couple of ins to mount one of the fans... still did not effexct temps at all.. .but when I mounted the nidec its fatty so I had no crews that would go through it.. so instead I cut off some wire hanger and punched it through knocking out a couple of fins to do so and just bent the wire once it got through the other side.
Just want to point this out that doing so did not effect anything in any way, and when looking for ways t o mount the fan, well it was ghetto and cheap but it worked.
Yah, thats my next step. ALthoug hteh vinegar solution bath I think is going to happen before I try that... I was wooried about placement before because of havingthe storm that because of using impingement jets that it HAD t o be right after the pump, not thinking that flow might not be different throughout the loop... still do not know for certain what is right but will try de"gunking" the loop before anything else. Lso any suggestions on additive?
I been using distilled and 10% prestone. will HO2 add a good antialgae formula too it? Or should I do the pop thing and spring for some water wetter forumla?
BTW - Were you saying res -> pump -> rad -> block as jph1589 suggested? No reason that can't work ...
