- Aug 20, 2002
- Brooklyn, NY
Nothing affects cooling like the amount of air moved through the rad. In my experience, it's usually easy to see the effects of different fans on temperature.
If you changed from a quiet fan to a loud fan and didn't see a change, then there might be something wrong with the way you're measuring temps because you really should have seen a temp change.
