- Nov 15, 2005
- Camarillo, CA!
OK well this isnt exactly original but i decided to do it. The reason for doing this was the fact i wanted to listen to music while riding my motorcycle, but being the cheap *** that i am i refused to spend money on "noise canceling" ear buds....
SO having an insane surplus of earplugs around my house (for use with shotgun shooting... usually shoot skeet 3 times a week) and another surpluss of ipod heaphones (i get them for free) i set off to make some noise canceling inear earbuds out of some stock ipod earbuds. god im so cheap
These are the earplugs i used
http://www.howardleight.com/family/index/1
They are very soft and very comfortable. after a few trial and error runs i finally came up with something that works way too good.
I cut the earplug in half then simply poked about a 3/16in hole in the center of the earplug. Then using a couple drops of crazy glue i attaced the edge of the earplug to the plastic rim of the earbud... all i can say is wow, all bg noise while riding is essientally gone, before i had to have the volume all the way up and would barly be able to hear the music while doing full throttle runs round my neighborhood. Now volume can be half way and i can always hear my music very clearly. Another great side effect from the earplug mod was the fact that there is now actual legit bass from these lil ipod earbuds, and they are very comfortable too.
PICTURES!
Call it ghetto or w/e but seriously if you have an extra set and availibity to some earplugs its worth a damn try... i use them now on my computer and not just for riding.... i had to lower my master volume from 20% down to 7% to have the same percieved volume and listening to music with them i hear things i have never heard before lol!
PICTURES!
