Sooo wait a second... in one post you apologize to me as you have been running overclocked at 4.2Ghz (causing your high temps), and then your next post you still claim its a faulty heatsink?
The Noctua cooler has been in the case for about four days now and I noticed the temps are dropping further. I'm now idling at 24C and running Prime 95 under full load at 63C. I'm very pleased with the performance of this unit. It was worth the extra cost.
As your paste/compound breaks in the temps will go down a bit. If some how you can go push pull you would see a little more. Have you checked the speed of the fan on your cooler. Mind run a little over 1400 attached to the cup fan connector on the motherboard. They do is quietly. Corsair recommend drawing in cool air instead of drawing air from inside the case and blowing it out. I have found that if your case cools properly you can exhaust with the cpu fan with out temp change compared to intake on the cpu fan. Something to tinker with while watching the temps.
