Hello all
Just wanna say I enjoy reading these forums and I've learned alot on overclocking already solely by reading other peoples posts, but I am presented with a small complication due to my purchase on the ram mentioned in the specs below.
Now so far I just wanted a simple OC out of my i7 cpu while still keeping my comp quiet, even when gaming. These very few changes to the BIOS in the Asus P6T Deluxe V2 has given me a stable and quiet oc from 2.8ghz to 3.65ghz, I really haven't changed much but it's definently stable cuz I've been using it for months and tested it several times.
OC Control = Manual
Vcore = 1.2000
CPU Ratio = x22
BCLK = 166
And that's it.
But the thing is, the ram listed in the specs below is the ram I just bought, I had slower (1333mhz) ram before these.
As you can see the specs on the ram I bought allows them to run safely at 1866mhz which is basically what I want to do, while still holding my CPU clock at max 3.7ghz.
I tried various bclk and ratio differences, but my comp won't boot with these ram if I go higher than around 1700 mhz on the ram? I'm guessing I need to change my QPI or Dram Bus Voltage to something else than auto, but I'm having a hard time understanding what they should be set to exactly?
I wanna set the dram bus to 1.64(max before it turns red in bios) and the qpi to something more appropriate to the ram, but I'm not sure what they mean so I'm abit scared to set em so high.
Can anyone give me some advice on how I should set my memory timings(which options it is on this mobo's bios) and on how I should experiment with my QPI / DRAM voltages?
I would apprecaite it greatly if anyone could share some advice!
CASE:
Define R3, No PSU - Silver Arrow
2x120mm front fans(intake)
1x120mm back exhaust
1x120mm top exhaust
(all fractal fans)
PSU:
750W Corsair TX CMPSU-750TXEU 140m
Mainboard:
Asus P6T Deluxe V2 Intel X58 DDR3
CrossFire/SLI
CPU:
Intel Core i7 930 2.80 GHz 8MB 130W S1366 /w Coolermaster Hyper 212+
GFX:
MSI N480GTX-M2D15 - GF GTX 480 -1.5 GB - DirectX 11 /w Accelero Xtreme Plus II @ VCore=1038, CoreClock=820, ShaderClock=1640(stable)
RAM:
KHX1866C9D3K3/12GX
12GB (4GB 512M x 64-Bit x 3 pcs.)
DDR3-1866 CL9 240-Pin DIMM Kit
(Further ram specs from manufacturers .pdf on my exact ram)
• JEDEC: DDR3-1333 CL9-9-9 @1.5V
• XMP Profile #1: DDR3-1866 CL9-11-9-27 @1.65V
• XMP Profile #2: DDR3-1600 CL9-9-9-27 @1.65V
CL(IDD) 9 cycles
Row Cycle Time (tRCmin) 49.5ns (min.)
• JEDEC standard 1.5V (1.425V ~ 1.575V) Power Supply
• VDDQ = 1.5V (1.425V ~ 1.575V)
• 667MHz fCK for 1333Mb/sec/pin
• 8 independent internal bank
• Programmable CAS Latency: 9, 8, 7, 6
• Posted CAS
• Programmable Additive Latency: 0, CL - 2, or CL - 1 clock
• Programmable CAS Write Latency(CWL) = 7 (DDR3-1333)
• 8-bit pre-fetch
• Burst Length: 8 (Interleave without any limit, sequential with
starting address “000” only), 4 with tCCD = 4 which does not
allow seamless read or write [either on the fly using A12 or
MRS]
• Bi-directional Differential Data Strobe
• Internal(self) calibration : Internal self calibration through ZQ
pin (RZQ : 240 ohm ± 1%)
• On Die Termination using ODT pin
• Average Refresh Period 7.8us at lower than TCASE 85°C,
3.9us at 85°C < TCASE < 95°C
• Asynchronous Reset
• PCB : Height 1.180” (30.00mm), double sided component
Refresh to Active/Refresh 160ns (min.)
Command Time (tRFCmin)
Row Active Time (tRASmin) 36ns (min.)
Power (Operating) 1.410 W* (per module)
UL Rating 94 V - 0
Operating Temperature 0o C to 85o C
Storage Temperature -55o C to +100o C
EDIT: I forgot to mention Hyperthreading is disabled! Also my max temps under heavy prime tests no matter how long they run is around 68-72C max on all 4 cores so I consider it stable and cool enough.
OC Control = Manual
Vcore = 1.2000
CPU Ratio = x22
BCLK = 166
And that's it.
CASE:
1x120mm top exhaust
(all fractal fans)
PSU:
Mainboard:
CrossFire/SLI
CPU:
GFX:
RAM:
KHX1866C9D3K3/12GX
CL(IDD) 9 cycles
• Posted CAS
• 8-bit pre-fetch
MRS]
UL Rating 94 V - 0
