- Jul 30, 2013
I am looking to get a stable overclock on my cpu @4.4 or 4.5. I have read trough all the information on this site but still could use some help. You can see my current specs below. Let the fun begin.
I was wrong. Its @ 1.5v. Thought it was @ 1.4v. I am using a H60 btw. I had it at 4.4 with my CM Hyper 212 EVO. Been a while, but I think I had the volts at 1.35v-1.4v.
Mr. Memphis I notice all of your voltages are low. You may need a new power supply in the future. You should check them with a volt meter. I'd hate to see you reach your OC goal just to have your whole system become toast because of a old/faulty PSU.
Yes would be wise to check real power supply voltage with a DMM. It is likely the Gigabyte board I/O chip causing the problem though and reading weird.
MOBO:GIGABYTE GA-990FXA-UD3 << There are a number of Revisions of those UD3 boards. Which revision is yours?
RGone...
http://www.overclockers.com/forums/showthread.php?t=727263&page=2
Begin with post #37 by tungureanu << he found a beta bios that has APM option so APM could be Disabled.
That REV 3.0 board was a pain for most that tried to overclock it. Giga has already come with the REV 4.0.
RGone...
I want to do a mild overclock on my amd fx-6300 with a coolermaster tx3 and the gigabyte 970a-ud3 rev 3.0 motherboard i want to go to 3.8 on the clock and this is it what is the multiplier i need to go to to get this
