OK, been doing a bit of reading, read the tutorials and guides and such. I have the old revision B3 of the Q6600, at standard clock speed, and with the standard fan. It has been on since this morning, but has been idle for a couple of hours at least. Booted up speed fan and reported the cores were idle at roughly 60 degrees each! Tried core temp as well and that reported the same temps.
Also, coretemp/cpu-z were both reporting the cpu to be running at 6x (1.6ghz) - i understand this is due to power saving methods etc, which I will disable in due time. However I ran prime95 for about 5 minutes, and it still stayed at 6x. Any reason why?
I only ran prime95 for about 5-10 minutes however, as when 100% load on all cores, core temp was reporting 85 degrees and rising, so i stopped it! Should it be this high? As far as I know the fan is running at 100%, I also have case fans (Antec 900 case) running on full as well. It is in a small room, but there is no heating on, and the tower is quite well ventilated.
Any ideas? I was considering starting to dabble in some mild OC'ing of it in anticipation of playing GTA IV, but with these temps I do not think it would be wise!
At the moment I cannot really afford to purchase a new heatsink/cpu fan, or afford the time to install it. Am I stuck at 2.4ghz for the time?
