MashR2toKill
- Sep 28, 2015
Hello. I have an Alienware Aurora R4 (I know, Shame on me) and the motherboard recently died. I have been looking for a budget friendly motherboard and I think I have found one that is under the $250.00 that I set aside for a motherboard and would like your input: https://www.asus.com/us/Motherboards/X79DELUXE/ Is it good for gaming and is it reliable?
If I do end up getting that motherboard, it also means getting a new case. I've been looking for one that's stylish and has a side window and is within the $80.00 that I set aside for a case and I think I've found one: http://www.eteknix.com/win-gt1-mid-tower-chassis-review/ What do you think? Is it a good and reliable case? I do have one problem with it though. It has a switch on the top that controls the fans. The downside is there is only two options: silent and turbo. I do not want that. I want my fans to dynamically adjust to the temperature of my rig. Is there a way around that and if so, what do you suggest.
If you have any parts that would be better than the ones I've chosen, feel free to post them down below.
Here are my specs in-case you need them:
Core i7 3930k @ 3.20Ghz
16GB GDDR3 RAM @ 1600MHz
GTX 780 @ Stock Clocks
1TB HDD 7200RPM OS Drive
3TB HDD 7200 RPM for Games
800 Watt power supply
Thank you in advance!
