I recently built my first rig, and have since been attempting to overclock my cpu. But I have had issues keeping the temps down and I am looking for any advice on how to do so.
My Rig
Zalman Z11 Plus ATX Mid tower case
Asus Sabertooth 990fx R2.0 Mobo
AMD FX 6300
Corsair H80 cpu cooler
Corsair HX 750 gold rated psu
XFX R7870 GHz Edition GPU
G. Skill Ares 2x4 GB 1866 DDR3 Ram
G. Skill Phoenix III 120GB SSD
I have my cooling set up with a 120mm fan as a front intake, 2 top mounted 120mm fans for exhaust and then the H80 set up to push/pull air from outside the case through the rad.
I currently have the cpu OC to 4.5GHz using only the multiplier and bumping the vcore to 1.4v I can run prime95 for an hour with no issues other than my temps are getting way to high( I think) cpu temp is peaking at 57 C and core temp hit 59 befor i shut it down.
Any ideas why this thing is running so hot?
My Rig
AMD FX 6300
