Temps shouldnt be close to 62C in the BIOS... It should be in the 30s likely.Temp didn't cross 62C. Later installed Aorux Xtreme 1060 6GB and overclocked to 4.5Ghz and leave it as it is on BIOS. Temp didn't cross 62C.
As Loch said, the CPU runs full clockspeed, but its only under a very light load (it is not idle). Correct that there isn't any power savings, etc. BIOS temps are always a few/several C higher than windows idle temps. It is not typical to see 50C+ out of a desktop with AIO cooler like that.
So again, those temperatures are not right. They are too high for just sitting in the BIOS.
Are you sure you used the right posts for the socket? There is something way off still bud.... I still think its a poor mount of all coolers honestly.
The temperature Under BIOS in B85M-D3H start reaching higher i.e. 80C and head-up to 91C. However, when I installed processor on G1 Sniper B5 then it stick. As far as I searched, found that BIOS boots the processor without power saving features and at higher Core voltages to ensure that it will initialize under any conditions. So its understandable that if processor taking full power then its become hot. Like you see in pic, I posted that CPU VCore is 1.224V and Processor running at full speed 4.6Ghz.
I already discussed this matter locally with IT Experts and they are saying the same.
I don't know about latest Motherboards, if BIOS developers put any Power Saving command.
However, here is the link, which I think described about processor well.
http://www.tomshardware.co.uk/forum/id-1800828/intel-temperature-guide.html
Your experts are a bit off....The temperature Under BIOS in B85M-D3H start reaching higher i.e. 80C and head-up to 91C. However, when I installed processor on G1 Sniper B5 then it stick. As far as I searched, found that BIOS boots the processor without power saving features and at higher Core voltages to ensure that it will initialize under any conditions. So its understandable that if processor taking full power then its become hot. Like you see in pic, I posted that CPU VCore is 1.224V and Processor running at full speed 4.6Ghz.
I'm thinking your worries are over my friend. I think you just had a bad board. It happens from time to time. We should hold off the celebration until you get the board up and running of course, but my gut tells me you'll be good when the new board arrives.
S-S make sure when you tighten cooler bolts you do it in an "X" pattern, tightening each one a little at a time in the same pattern until they are all snug. 1-1.5 turns each go around the pattern.
Wondering what ICs 'went bad'. Also wondering how that would cause bad temps on some cores but not all. The same voltage is fed to to all cores afaik, so a bit confused....
We still have a self admitted bad mount as well...a very confusing thread honestly.
I hope kts fixed with a new mobo... if it does, id love to know exactly what happened.
