- Oct 9, 2013
- Philippines
- Thread Starter
- #41
Your processor's integrated memory controller is capable of handling 1866 ram but that does not mean you can run ram rated for 1333 at 1866 speeds. If you want to run 1866 memory speeds than buy 1866 rated ram. I would be skeptical at trying to make your ram run at 1600 as well, even with loosened timings. Even if you can get the ram to be stable at 1600 with extra voltage and loosed timings the performance offset from loosening the timings that much may negate any performance gain you expected to see from the higher frequency.
oh ok.. so do you think its better to leave the settings at the current values with the current hardware i got? do i still need to change any settings on the bios based on the pictures?
