- Jul 15, 2013
ok retro friends i need some help installing my 240mm AIO radiator into my case. only problem is with the fans attached the rad doesnt fit because the cpu is to close to the top of the case. my question is would i be able to install the water block and radiator inside the case and then install the fans on the top of the case? and if i do install the fans in the top of the case will that affect my cooling i dont seem to have any other options pix are below any questions ask
i have a second case fan for the rear of the case and 2 intakes in the front all 120mm case fans if you look at the pc proclockers pic thats where id have to install the rad fans and they wont be touching the rad will that be an issue
