I have had a lot of interest in water cooling over the years but have been holding off until my current computer is about to go. Well the time is now, instead of it about to go, it went. The mobo died and i decided to finally go about building a new rig with WC.
So I have been reading a lot about water cool lately and have done a lot of research. I have planned and planned and planned and replanned.
I have come up with two setups for my upcoming rig. At the end I have questions that need to be answered to help me better prepare for the upcoming build.
Computer Components Used for Both Setups:
Case/PSU:
- Antec Twelve Hundred Black Steel ATX Full Tower
- CORSAIR CMPSU-750TX 750W
Mobo:
- ASUS M3A79-T Deluxe
CPU:
- AMD Phenom II X4 940
Memory:
- Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
HD:
- Western Digital Caviar Green WD10EADS 1TB 32MB
Vid Cards:
- HIS Hightech H487FT512P Radeon HD 4870 512MB (for crossfire)
DVD Drive:
- LG 22X DVD±R DVD Burner Black SATA Model GH22NS30
Fan Controllers:
- Scythe KM02-BK 5.25" Bay Fan Controller
- AeroCool PowerWatch-BK Multifunction Panel
Case Fans:
- Antec TriCool Blue LED FAN
WC Components Used:
Pump:
Swiftech MCP655
Radiators:
Danger Den Black Ice GTX Xtreme 360 Radiator (Setup #2)
Danger Den Black Ice GTX Xtreme 240 Radiator (Setup #1)
Danger Den Black Ice GTX Xtreme 120 Radiator (Setup #1)
Rad Fans:
Reservoir:
XSPC Dual 5.25" Bay Reservoir - Black
CPU Block:
Koolance CPU-350 AT Acetal Liquid Cooling CPU Block
VGA Blocks:
Koolance VID-487 (Radeon HD 4870) VGA Full Card Water Block
NB Block:
Koolance CHC-122 (MB) Liquid Cooling Chipset Block
SB Block:
Koolance CHC-125 (MB) Angled Liquid Cooling Chipset Block
Mosfet (Thermal Regulator) Block:
Koolance MVR-40 Motherboard Voltage Regulator Block
Mosfet (Thermal Regulator Plate:
Koolance MVR Heat Transfer Plate 107.5mm (MVR-PLT1075)
Memory Block:
Koolance RAM-35 Single Memory Liquid Cooler
Hard Drive Block:
Koolance HD-60 Hard Drive Liquid Cooling Block
Tubing:
Feser Tube Active UV Hose - 1/2" ID (3/4"OD) Anti-Kink Tubing - Clear / UV Blue
Thermal Sensors:
Bitspower G 1/4" Temperature Sensor Stop Fitting
T-Lines connectors for sensors:
Bitspower G1/4" Crystal T Block - 180 Degree
Cooling Fluid:
Feser One Non Conductive Cooling Fluid - 1000 ml - UV Blue (F1-0001)
Fittings:
Bitspower FrozenCPU Chrome G1/4" Barb Fitting - 1/4" ID
Clamps:
Herbie Clip® Nylon Hose Clamp Size H - Blue
Setup #1 - Two Radiators
All the components above are being used with the exception of the Danger Den Black Ice GTX Xtreme 360 Radiator, which will be used in setup two.
I have made two diagrams for setup #1. This setup uses two radiators rather than one. It uses the Danger Den Black Ice GTX Xtreme 240 Radiator and Danger Den Black Ice GTX Xtreme 120 Radiator. I have also been going back and forth on possibly adding another pump and maybe another reservoir (EK Waterblocks EK-Multioption RES 100 rev.2??) since my loop is pretty big. The case fans, PSC, and rad fans all have arrows in the direction the air is flowing in and out of the case.
Each little square on the diagram represents 1/5". I got most of the measurements for the computer components from specs I Pulled off of the web. The actual size and fit should be pretty accurate, give or take a few millimeters. I also inspected and measured the Antec Twelve Hundred Case at a local computer store so that I wouldn't have to estimate certain things about the case that can't be measured by specs.
On the other hand, I could not find a definitive measurement for the Video cards. I see the Width and Height pretty much stay the same throughout the web, but the length, which IMO is the most important peice of info for my setup, fluctuated between 7" and 9.1" for the model number I have. My diagrams show 7" video cards. I am afraid that if it is 9" in length it might not allow me to water cool my SB, therefore nulling the need to purchase any Mosfets, NB, SB blocks since the MOBO has one big heatsink for all three.
Diagrams for Setup #1:
Case Setup with Radiators before the rest of the WCS is added.
Case Setup with WC Components.
Side Panel Setup
Setup #2 - One Radiator
All the components above are being used with the exception of the Danger Den Black Ice GTX Xtreme 240 Radiator and Danger Den Black Ice GTX Xtreme 120 Radiator, which were used in Setup #1.
I have also made two diagrams for Setup #2. This setup uses one bigger radiator for the whole loop. It uses Danger Den Black Ice GTX Xtreme 360 Radiator. I like this setup a lot but am unsure how well the loop will do in keeping the cooling fluid cool throughout the loop. This is the reason why I came up with setup #1.
Diagrams for Setup #2:
Side Panel Setup
Conclusion:
Those are my two setups that I beleive would best fit my needs after all my research. However, like I said earlier, this is my first watercooled system and no matter the amount of reading I do on the web, experience beats it.
Questions:
- Will my video card cover the SB of my mobo making it not WCable?
- Should I change my flow?
- Should I change out any of my WC parts or components?
- Should I use two pumps? Two reservoirs?
- Is my setup good?
- Should I change my air flow?
- Where should I get my parts?
Anybit of advice would help and I really do appreciate all the things this forum provides. Thanks in advance for all your help, and hopefully I can get this thing up in a few months.
~papapnoi~
Case/PSU:
Mobo:
CPU:
Memory:
HD:
Vid Cards:
DVD Drive:
Fan Controllers:
Case Fans:
WC Components Used:
Pump:
Swiftech MCP655
Radiators:
Rad Fans:
Reservoir:
CPU Block:
VGA Blocks:
NB Block:
SB Block:
Memory Block:
Hard Drive Block:
Tubing:
Thermal Sensors:
Cooling Fluid:
Fittings:
Clamps:
Side Panel Setup
Side Panel Setup
Conclusion:
Questions:
- Is my setup good?
~papapnoi~
