Hi there!
My '09 machine is still running, and I've been meaning to push it to its limits since last year. Recently I scored a free copy of BF4 and I'm interested in finding out how far I can go with what I have (instead of having to buy a new system).
My specs:
MOTHERBOARD: EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4240124&CatId=3495
PROCESSOR: Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115037
MEMORY: Patriot Viper II 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory (X2=8gb) - http://www.newegg.ca/Product/Product.aspx?Item=N82E16820220426
GPU: EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130434
I know specs are a tad old, but I rarely game anymore, and this system glides through whatever I've thrown at it to date!
I'm a total noob when it comes to overclocking. This is my first attempt at doing so and I'm hoping to reach 4.5Ghz (or at least best the 4Ghz mark). I know the performance difference between 3.9 and 4.0 is negligible (1-2%?), but I do want to see what this guy is capable of doing!
Here's what I got so far:
Idle temps: 35 Celsius
Load temps: 45 Celsius
*note* I've set CPU core to 1.312 V, but I think Vdroop is increasing/decreasing it according to what it thinks is best.. CPU idles at 1.312V for some reason, but as soon as load is added, it drops to 1.296. Perhaps I should just disable Vdroop...
I've tried bringing up the core voltage (up to 1.4v) and tried increasing ram voltage (up to 2.15). Even went ahead and underclocked the ram to see if cutting some slack does anything, but nope...
I've been able to run prime95 stable with a similar setup for over 24 hours (only difference is that RAM was clocked .1V lower than what it's at now (2.0V now)).
Is my RAM or MOBO holding me back? Every time I increase the the FSB to > 444.44, I hit a boot loop with Windows. The BIOS posts, but soonafter I get an option to run startup recovery or boot into windows normally. When I select either option, I get a "Windows is Loading Files" screen with a bar right above it. Sometimes the bar doesn't complete and just hangs at that screen. Other times the bar fills up, and computer just boots all over again -- starting at BIOS post.
I'm not too sure what's left to try... I don't mind taking my CPU Core voltage up to 1.6.. I know it'll damage my processor, but truth be told, I'm looking to building a system within the next year. I'm willing to take some risk, but would like to avoid if possible (at least until I've build my next system).
Anyone have any suggestions?
On a (un?)related note, as I was stress testing my computer today while at school (just decided to run another 24/hr stress test for reasons unbeknownst to me..), my computer crashed and a BIOS error was left once it booted.
Lately I haven't received any BSODs, but this may be related to some voltage change. I'll run another 24hr stress test tomorrow and see if this is a recurring issue. If not, I'm just going to let it slide.
Here are the details of the BSOD:
I'd appreciate help tackling OCing my CPU past 4.0Ghz if anyone has any input!
Thanks a lot =]
My specs:
Code:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF960000F79DF
BCP3: FFFFF8800E7C7FF0
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\111413-27019-01.dmp
C:\Users\Wolf\AppData\Local\Temp\WER-60091-0.sysdata.xml
Thanks a lot =]
