- Feb 24, 2001
I have the system in my sig in a mATX case. I have managed to fit a full size ATX powersupply inside, which is one tight fit.
Here is what I have right now:
The only thing is for the next 2 weeks Im stuck with the retail AMD heatsink. I think I have a faster fan than the one it came with.
Load temps are 47-51C
idle is 41-45.
Do any of you guys have any suggestions on how the fans should be setup.
Also the fans labeled 80mm, Im not sure if thats their size, all I know is that they are bigger than regular case fans. They are pretty big, and take up alot of room on the side of my mATX case.
Thanks in advance...
idle is 41-45.
