Hi all!
I am going to buy a new computer, and I basically have everything now. Except for my CPU cooler. I will be using it on a AMD Phenom II X6 1090T, on a Asus Crosshair IV Formula motherboard. I am not planning to be pushing extreme limits, around 4GHz I guess. My budget is about $60-$70 or 40-50 euros.
I have been looking around a lot on the internet, and I was thinking about getting the Zalman CNPS10X Extreme first, then saw that the Zalman CNPS10X Performa was better, with two fans. It might also be a bit cheaper. My question is: Should I just stick the the Extreme? Or go with the Zalman Performa and add another fan? Or should I mount 2 identical fans? Blue LED's are preferred. I was thinking about getting 2 CoolerMaster R4 SickleFlow's (120mm, it says that they are Case fans on the website but they should also work on the CPU right?). But if I am replacing the original fan on the Performa anyway, wont it be better if I'd just get a single heatsink, without fans?
I'm a little confused on if it would make a difference.
Any help greatly appreciated!
Thanks
Thanks
