- Dec 2, 2003
Ok well i have a 2x16 LCD
first of all i need a 10 ohm resistor (1/4w/.5w) so i just go here
http://www.allelectronics.com/matrix/One_Half_W_Resistors.html
and enter 10 for cat# and then 10 for quanity (since thats the minimum) right?
and then which pots do i get? i need a 100ohm and a 10kohm but theres so many
http://www.allelectronics.com/cgi-bin/category.cgi?category=470&type=store
do i get the 100ohm trim pot or the 100ohm linear taper?
and then id just get the 10K LINEAR POT W/CENTER DETENT?
is that right? i need to know cuz im ordering today, or tomorow
edit: o btw, for getting power to the lcd, does it matter which molex i use? in the guide on ocf, it says to use a female, but shouldnt i use a male since im plugging it into the psu?
