I am paying attention.
So to over clock the below i need a better cooling system and a better case for room to fit cooling system in.
Asus Crosshair V Formula-Z Motherboard (AMD 990FX/SB950, DDR3, S-ATA 600, ATX, PCI-Express 2.0, … £167.98
AMD FX8350 Black Edition 8 Core Processor (4.0/4.2GHz, 8MB Level 3 Cache, 8MB Level 2 Cache, Socket … £148.79
But saying that will the below fit in the tower i have at the moment and still be able to run it at 4.2ghz turbo boost without issues? or will i still need a better cooling system?
Those parts will fit in the box. It'll be the aftermarket cooler you'll need to pay attention to. The height of the cooler and width of the box. Will a tower style cooler fit inside with the side door on. Also plan on putting some fans in the front of that box for cool air intake. I just checked the specs on that case. Is this it. http://www.novatech.co.uk/products/components/cases/cases/galaxy3.html
I would look at upgrading it. You're just not going to get the air you need.
I would go with something more along these lines. http://www.amazon.co.uk/Corsair-Car...8&qid=1389109265&sr=1-1&keywords=corsair+300rIt's 20 pounds more but. It will give much better cooling, cablemanagement and has a cutout behind the Mobo which is important.
In just a minute I am going to get out of this thread and leave it alone. But I have a question. Corsair Carbide Series 300R CC-9011014-WW Mid-Tower Gaming Case << Where to do you put a dual radiator AiO setup? The mobo seems right up against the top of the case.
RGone...
