Hey guys first and foremost i wanted to say a massive hello to your community. You guys seem very informative and its been a pleasure reading through some of your advice!
On to my problem
My System as follows
I7 2600k @ 4.6Ghz < this is the issue
Asus P67 Sabertooth
Prolimatech Megahalem Cpu cooler
G skill Ripjaw X DDR 3 @ 1600Mhz
OCZ gold modular 1000w Psu
Right i brought this pack pre overclocked however i beleive my Vcore is well high as its set to 1.425, which worrys me quite a bit as the idle temps are about 28 degrees and 100 per cent load rounds out at about low 80s, I have tried to set the vcore lower however i just end up with crash's. I have heard playing with offset mode might help but i would like further opinions on this and how to use it safely.
my settings in bios
Ai Tweaker
AI Overclock Tuner- Manual
Turbo Ratio - leave this
By all cores - 46
Internal PLL Overvoltage - Enabled
Memory Frequency - 1600mhz
Dram Timing Control - Press Enter
Dram CAS Latency - 10
Dram RAS To CAS Delay - 10
Dram RAS PRE Time - 10
Dram RAS ACT Time - 28
CPU Power Management - press enter
CPU Ratio - 33
Loadline Calibration - Extreme
CPU Voltage - Manual
CPU Manual Voltage - 1.365v - 1.400(max)
DRAM Voltage - 1.560v
CPU Spread Spectrum – Disabled
If anyone can have any input into this i will appreciate it no end.
Kind Regards
W
On to my problem
Asus P67 Sabertooth
my settings in bios
Ai Tweaker
By all cores - 46
CPU Ratio - 33
Kind Regards
W
