ItWasGreat
- Jul 10, 2016
So recently I upgraded my motherboard and got a new Gtx 1080 waterblocked gpu and i'm running into an issue regarding CPU temps. Previously, my idle CPU temps for my 5930k overclocked to 4.4 was around 39/40C, now it's idling around 49 and during heavy playing in Witcher 3 it hovers around 60, while previously only getting to about 45C. My radiators and pump have not changed so why the increase in my temps? I checked the thermal paste, re-applied and still getting high temps, i'm at a loss for the reasons for the sudden increase in temp, any suggestions?
More information about my PC, I upgraded from a MSI X99A Krait Edition to a MSI X99A Godlike Gaming Carbon and from a EVGA GTX 980 Hydro Copper to a MSI GTX 1080 Seahawk EK X. My loop consists of AlphaCool 360mm radiator(push/pull) -> EKWB Supremacy EVO -> EKWB Bay Res/Pump -> AlphaCool 240mm radiator(push/pull) -> GPU -> back to top radiator (360mm). I also took my waterblock apart and cleaned it as best as i could, also my radiators have been properly cleaned of dust and debris (if any), but honestly i'm at a loss as to why even atr 50% CPU usage the CPU spikes up to 64C on water!! I've re-applied thermal about 5 times in the past day and it hasnt made a difference at all. Hopefully you guys might be able to figure out what the possible problem might be.
