To answer your question "Actually what's the different between setting a specific voltage and an offset ??"
In older chipsets, setting a specific voltage caused the CPU to ALWAYS run at that specific voltage (instead of throttling with speed as needed), whereas setting an offset would modify the default voltage by something near your specified offset.
Not sure if it still functions that way in the newer chipset, as I don't have one at my disposal to experiment with.
I see, I never tested it. But it seems like that is the reason. Because I check out a few videos on how to OC 10900K, the guy told us to set a specific VCORE Voltage first before trying to setting it as Offset / Adaptive.
He said this will hard lock the voltage to the figures you've punched in and once you know it's stable, from there on switch back to Offset and adjust to the amount of voltages you want to offset.
For my case, even I set to Offset. When I first run Cinebench the very first few second, from what I reading on CPU-Z. It will still spike up to 1.35 - 1.36V.
Then It bring it back down to 1.3111V ( Now I have it set to Offset 0.050 ).
Also I'm using Balanced Power Plant, so when my Clocks go down the voltage will do too. I find hard locking the voltage to say 1.35V seems excessive...even when you don't need it.
Won't your CPU be always running hot ??
Also I would like to update, it seems like 1.3111V Offset help amazingly....my Clocks are still at a solid 4.9Ghz at Cinebench but I've shaved off like 5 - 6C now. Also I notice I'm consuming 20W less too during Cinebench.
Usually it was like 80C or so during Cinebench runs, now it's only like 75C.
I also tested it in AC Odyssey, during Benchmark it was spiking up to 70C and more sometimes. Now it's keeping at a cool 55C - 67C. I never see it touching 70C yet. Hopefully it stays this way.
But today it's a cool day, it was raining earlier so weather is lot cooler than usual.
But if this small Offset really did the trick then this is a huge win for me. It's kinda mind blowing, that only Offsetting a mere 0.050 can yield such a big differences....
It seems like you can go WAY LOWER than this....I've seen people doing OC but only at around 5.0 - 5.1 range with like only 1.28 - 1.29V...while at 5.2 - 5.3 it was only like 1.32V which is still lower than the Stock settings, if this is the case, why the hell Intel / ASUS is pumping so much excessive voltages into the CPU ???
