Hello all,
Thus far I've OC'ed my i7 2600K to 4.9GHz @ 1.440v. I've run Prime95 with the standard tests over 2 hours and the temps (using RealTemp 3.67) maxed out at 83C. When I cranked up the Vcore to 1.500 and the mutilplier to 50, the temp maxed out at 92C within the first 6 minutes (no BSOD or shutdown) I just stopped it because I'm not sure just how far I can push the temps on this CPU.
I'm using a Corsair H100 in an Antec 1200 with all fans set to low (except the rear 2 fans, where the radiator is mounted, which are set to high) and are pulling air from the inside to outside.
With the exception of the CPU temp, I'm very impressed with how cool the total system runs. (Compared to my old dual-core AMD system where the case gets warm while idling using the stock HSF system).
So, my question is just how far can I (safely) push the temps on this Core i7 2600K? I've followed the OC'ing guide as described here http://hardforum.com/showthread.php?t=1578110 for the most part; I'm using the X.M.P. of the RAM, BCLK @ 100.0, Turbo and Hyperthreading enabled, etc. Most settings are as described in the article or left at their defaults.
Are there any other specific "tweaks" I can use for OC'ing? or to reduce the temps of the CPU?
I'm more or less just curious what this CPU can do. I don't plan on using anything beyond 4.8GHz for everyday usage as that is already a huge improvement over stock values and quite impressive.
Please note, I do have 3 more 120mm fans that I could install into the case to help with cooling other parts of the motherboard, if necessary.
Thanx in advance,
Cheers,
ziggy1971
I thought my other PC details would show up in a sig, but I guess not, so please see my profile for full details on my rig.
Thanx in advance,
Cheers,
ziggy1971
