fatfunkymonkey
- May 16, 2015
-Hello
I've decided to build a PC which is a first for me. During the past few weeks I have researched everything I could about the process and am at a point where I feel comfortable to actually build my PC. I've selected all the required parts to build it but I've decided to go with Liquid Cooling which I don't know to much about. I want to cool my CPU and GPU.
CPU: Intel® Core™ i7-4790K Processor
GPU: GeForce GTX 980
The case I have selected is a Corsair 900D. I know what components you need for liquid cooling but I don't know how you actually set it up. The radiator I am going with is the Black Ice Nemesis GTX series. I was wondering if having a 480GTX at the top with another at the bottom of the case would work well and how the tubing would be set up also. The water block for the CPU is a EK Supreme HF. The water block for the GPU is a EVGA Hydro Copper Waterblock for GTX 980. I haven't selected a reservoir yet because I don't know what type I should get and where I should place it inside the 900D. The pump I am getting is the Swiftech MCP655. I'm Look for high-end quality tubing and fittings. I need help mapping out where it would a go and getting an idea of what the result would look like. As you can tell I am a newbie when it comes to Liquid Cooling. Any help is very much appreciated.
