- Dec 15, 2009
My work has changed so I'm going to be using the following rig as a workstation:
Intel Core2Duo E6400 OC'd @ 2.6GHz
4GB DDR2-800 Corsair XMS
MSI P6N-SLi 650i Motherboard
I suppose my question is rather straightforward but after spending a couple of hours on Newegg all the RAID controllers/cards I found had absolutely abysmal reviews that I found rather shocking across the board. All cards, regardless of the brand, seemed the suffer from the same issues. IE the HDDs became corrupted, RAID0 ceased to function, ETC...
ALL I need for this station is STABLE RAID1/Mirror with (2) 1TB Hard Drives. I need absolute stability so I'm hoping my fellow OCF'ers can throw some options my way so here are my questions:
1.) What Hard Drive brand do you guys recommend? I used to <3 Western Digital but I've had the same stupid 250GB AAKS Hard Drive fail on me three times now.
2.) Can I get away with buying a "cheap" RAID card for $80~ or do you either spend big or go home when it comes to true RAID cards?
Having failed at 2.), can anyone here speak to how the older Nvidia chipsets handled RAID? I couldn't care less about performance but I want to make sure I don't boot up one morning to find a nice flashing "REBUILD" on my POST if that makes any sense.
