Hi all first of all great site! I am building my first pc and need some help on ram for my mobo. First of all the mobo is a MSI 890FXA-GD70 AM3 socket. On the mobo's specs it says this for the ram : Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) DRAM, 16GB Max. Ok so originaly i was going to put some 1600mhz ddr3 in but the way i read these specs tells me that the max i can put in is 1333mhz then i have to oc it to get 1600mhz then 1800mhz etc etc. Is this correct the way im reading this? Or can i put 1600mhz strait in? Any help appreciated as its holding up my build as i cant decide what ram to use. Thanks!
