Way out of my depth on graphics i'm afraid, dont play games so havent delved into the OCing of Graphics cards abyss. Someone else will be able to advise, possibly DaFanMan.
Hood
appreciate the help anyway man. i've been looking on the net for fans....is my MB a 462 socket? can't find it in the manual anywhere. also the aero 7 lite is aluminum is this sufficient compared to the 7+ with all copper.....i'll do some more research but maybe you can post some comparisons if you have any links
Fragile-x,
Like hood, Ive been out of the graphics card overclocking arena for awhile.
My albatron ti4200p 128 mb card does not overclock very much before artifacts, and other undesirable effects show up, so I just run it at stock speed, besides that when I was into overclocking graphics cards, the only place that showed a real world difference was in benchmarks, not actual game performance.
Probably you should hit some video card specific forums to get better info
does my MB actually have thermal sensors right on it? i installed motherboard monitor and it is saying that the case is 32 C and the cpu is 56C .
is this right? i didn't know they had thermal sensors on them? What is a good temp to NOT hit?
i have thermal probes on my case that are supposed to give an LED reading on the front of the case (ngear case) but they just don't seem to wanna work.
Yes all modern mobos have sensors, have done for quite a few years now. Your temps look about right, main thing is dont stress if you are not having heat related issues.
Hood
