Hi I have a "QUIK SILVER2-CMT" mobo
From many hours of research on the net I believe "FIC" made this mobo
for compaq (oem) sometime around 2001
The problem is that the front panel connections for stuff like the power switch, reset switch led's etc are not marked, well 3 are the rest are not and Im not sure of the configuration, this is the first time Ive been stumped trying to wire the FP
Ive literally spent over 6 hours looking for info, some of the best info was found here of coarse: http://www.overclockers.com/forums/showthread.php?t=464515&highlight=QUIK+SILVER2-CMT
but not good enough to figure out the FP connections, does anyone have a secret to figuring these out, I downloaded every single socket-a mobo.pdf manual from FIC and looked through them hopeing I could unravel the mystery or find a pattern but Im still unsure.......... and im afraid I may short circuit or destroy the board if I get those connections wrong
help
help
