- Dec 6, 2007
Currently I have the "Danger Den HDPE 5 1/4" Bayres":
I was having problems with the res leaking around the fill port (even after making sure it was real tight). I have one in, one out, and one plugged port. At first I thought the issue was with the orientation of the in/out flow, so I reversed it. Now I'm back to having the same problem with leaking around the fill plug.
Am I filling the res too full? Is this model just prone to leaking at that spot? Any suggestions for a better 5 1/4" res?
Current build in an Armor TT case:
D-Tek FuZion CPU block
DFI LanParty Dark P35-T2RS
Swiftech MW30 Chipset block
Swiftech MCR220-QP
Eheim 1048
7/16" Tygon R-3603
3 x CoolerMaster 12025 Fans
1 x Thermaltake TT-9025A @ 7 volts
Swiftech MCR220-QP
Eheim 1048
7/16" Tygon R-3603
