- Mar 14, 2013
- Massachusetts
How's it going everyone, been a minute or two since I've posted here but have still been a long time browser. No better way to get back into the fold than by starting a thread for the design of a new build I'm planning on the Lian PC-C3000 Case. My current build, which can be seen in my sig, has been solid for a long time. But time for something new to be built in a larger and more scalable case.
This will be a completely new computer aside from reusing my current EVGA PSU and fans from the current build, and temporarily using my current 2x EVGA 780ti Classys. The GPUs will be upgraded later this year or early next. My primary goal for this, aside from just upgrading the components, is to have a case that I'll realistically never need to upgrade from.
Here are the core components as of now...
Case: Lian LI PC-V3000WX https://www.newegg.com/Product/Product.aspx?Item=9SIAFST6XC2791
MOBO: EVGA Z370 Classified K https://www.newegg.com/Product/Product.aspx?Item=N82E16813188193
CPU: Intel Core i7-8700K https://www.newegg.com/Product/Product.aspx?Item=N82E16819117827
RAM: G.SKILL TridentZ Series 16GB (2 x 8GB) DDR4 4133 https://www.newegg.com/Product/Product.aspx?Item=N82E16820232316
Boot/OS SSD: Samsung 970 EVO M.2 2280 500GB https://www.newegg.com/Product/Product.aspx?Item=N82E16820147690
2nd SSD: Samsung 850 EVO (Already own)
PSU: EVGA SuperNOVA 1000 P2 (Already own)
GPU: EVGA 2 x 780ti Classified SLI (Already own)
My plan for the watercooling is to take advantage of the Lian's radiator space as much as possible with the goal of going a little overkill as the cooling components will probably be my build for a very very long time. I plan on having the following radiator setup for just my CPU to start, with the plan of putting a GPU (maybe 2) on water later this year or early next.
Bottom Chamber: Alphacool Monsta 480mm
Front Chamber: Alphacool UT60 360mm
Top Chamber: Alphacool UT60 420mm
Additional Components:
CPU Block: EK-Velocity RGB - Full Nickel
Pump/Res Combo: EK-XRES 140 Revo D5 PWM
Tubing: PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD
Fittings will all be Bitspower
Kill coils all over, one for each rad, and one in the reservoir
IC Diamond for the CPU/Block Paste
I think I've come up with a good drainage solution for the build, absolutely open to feedback and ideas on this (and in general). Having a solid drain setup is critical to me after neglecting to setup a good solution on my current build which was an oversight. I'm attaching some pictures which show what I'm envisioning here, as well as for the overall loop.
The only thing I haven't fully thought through yet is a fill solution. Something I love about my current build is the chimney fill port I setup which allows me to fill it from the highest point in the loop. Although it is a very simple loop, I imagine the ability to do this in any setup makes life easier.
Some questions...
--I'm not completely sold on the EK Pump/Res combo, only because I kind of would like something with a bit taller reservoir. Ascetics aside, are there any real benefits to having a bigger reservoir? The EK is only 140mm. Any good alternatives to the EK combo?
--Based on the loop design below, any concerns of a single D5 being able to run with this? Also, as a GPU will be put on water at some point, would a single D5 still be sufficient here?
Definitely looking forward to hearing feedback. Folks here were a tremendous help on my first build, the words of wisdom are highly appreciated and valued
Some questions...
