- Jul 29, 2011
- Buenos Aires, Argentina
It has red arrows pointing up or not?
Cool!
6 x 10 buck fans, for 50!
Pretty sweet deal...you won't regret getting those.
I recommend silentpcreview.com for fan reviews.
They are the most detailed fan reviews I have found.
Thanks for the info. I think I actually found many reviews from that site. But most people just find out the DBA, they don't really say if its quiet. And quiet to many people is different than my opinion.
I suggest getting some inexpensive sound deadening material and applying it to the interior of the case. I bought a roll at lowe's for about $18 and it is enough for 3-4 cases. It helps a lot with flimsy steel or aluminum side panels. It is called peel & seal and is a roll 6" high and 25' feet long. It has some black sticky stuff, and a soft aluminum surface. It is about 1mm thick.
