- Mar 7, 2004
- Phoenix, since 03/2014
Preface: The system for this is Kubuntu 14.04 64-bit (dual boots Windows 10 though)
My system is as in the sig. I currently have an EVGA GTX 460. It has two DVI ports and one mini HDMI port.
Right now I have two monitors and everything was going fine until we actually got a TV last week (haven't had a tv in YEARS, and even then it was a 19" tube!). So I connected it to my video card and couldn't actually get all three displays working together at the same time. Turns out that while the hardware has three ports, it doesn't actually support using all three simultaneously (I guess they're there to give options). Apparently this is a Fermi limitation that was addressed in future architectures.
The three displays are thus. I provide links so you can see specs.
Monitor 1: HP ZR24w
Monitor 2: HP Z24i
TV: Sony KDL40W600B
The two monitors apparently don't have HDMI inputs, so this would need to be taken into account. When I got the GTX 460 about 3 years ago, I had a Radeon X1950 XTX, and the GTX 460 was an enormous jump in terms of horsepower. So I'm looking for a card that will be as close as possible to a similar jump while also being able to simultaneously use all three of my displays and be less than $200 (if possible; I'm willing to go a tad over). I could research this on my own, but between babies and work I just don't have the time for this stuff that I used to, so I'm putting my faith and trust in my OC buddies!
Monitor 1: HP ZR24w
Monitor 2: HP Z24i
TV: Sony KDL40W600B
