...and more cooling at higher RPM, especially with higher FPI rads.
I'm on the other side of the spectrum... I'd rather run a single fan on the lowest setting anyway. Two just makes more noise.Most AIO's don't have thick rads or high FPI.
Oh I believe you... as I said, several ways to skin this cat.
I just find that a single quiet fan already at its lowest setting is quieter than two fans at their lowest setting. If it ramps up under light load, change the curve.
I have 3 Noctua NF-A12s hooked up to the AIO at 2000rpm and don't notice the noise at all while gaming. I think I hear the other case fans over those to be honest.
No, you wouldn't notice it while gaming. It was at idle and light computing is where I see the noise benefit. With only push or pull at low fan speeds I wasn't getting enough flow through the rad to keep temps down to the level I wanted due to core turbo spikes. If I set the fan cure to reduce temp spikes the fans would ramp up and down. The push pull setup gives much better flow at low ran RPMs and cures that issue.
Just won a EVGA CLC 280mm All-In-One for $70 plus shipping on ebay yesterday. It was brand new in box from an estate sale. Since I don't have on hand another set of 140mm fans to make that one push pull at the moment, I'll be going with the stock one side fan arrangement. Maybe the extra rad area will compensate for that. We'll see how that goes.
Let me check out that memtest USB boot issue. I've always run it from an optical disk.
I certainly would try a different driver for the GPU. Can't hurt anything.
Run system file checker and run it this way: https://support.microsoft.com/en-us/help/4026529/windows-10-using-system-file-checker
I didn't have a problem booting from a memtest86 USB stick. Instead of making the USB stick the boot priority, try using the boot order hot key and choose the UEFI option for the stick in the boot options list.
Okay so the build is randomly restarting while either browsing the web or watching youtube... I can play games all day and not have any issues.... Bad PSU? I've run tests on the RAM and hard drive. Windows is updated as well.
