VoodooVyper
- Apr 18, 2013
Hey everyone, first post on this forum. I know this is a very common issue, but hear me out.
I built this rig back in September and have had this issue ever since. When I play video games, the comp freezes up completely and needs a hard reboot. Ctrl Alt Dlt or Alt Tab do not work. This freeze up can happen an hour into playing, or 10 minutes, or 4 hours... seemingly random.
As mentioned, this issue has been off and on. In another thread, I was recommended to update the BIOS. Which I did, and it seemed to fix the issue months ago. Then it started doing it again and what do you know, a new BIOS update and it fixed it again. Now it's doing it again and the latest update to the BIOS does not have any stability fix and coincidentally the issue continues to happen. The only thing I've changed since it started doing it is I added a NZXT Sentry 2 LX and a set of headphones.
I'm sure the first response will be about heat, but my temps are well within range (less than 50 degrees Celsius under load). I have also ran through memtest with no issues. I have reseated everything there is to reseat. I have reset the CMOS. My GPU drivers are always current. I have tried each RAM stick individually and in different ports. I recently purchased a second GPU and have tried each individually and in different slots and still the same issue.
My main problem is not knowing what's causing it. Is there someway I can actually see why the computer crashed? No dump file is being produced. Is there a system log that records these things? Another member swapped out every single piece in his machine until he realized it was his PSU, I really don't want to follow that same path.
My set up:
Intel Core i7-3770K
CPU Cooler: Zalman CNPS9900MAX-B
Asus SABERTOOTH Z77
G.Skill Ripjaws 16GB DDR3-1600
Crucial M4 256GB SSD
Seagate Barracuda 2TB 7200RPM HDD
Kingston HyperX 3K 120GB SSD
Gigabyte GeForce GTX 670 2GB x2
Cooler Master HAF 932 Advanced
Cooler Master Silent Pro M 850W PSU
Asus VS247H-P 23.6\\\" Monitor
CyberPower 1350A UPS
As far as overclocking, the GPUs remain untouched, but the CPU has been oc'd to 4.2 in the ASUS bios ui. The issue still happens when the CPU is not oc'd.
I have also been recommended to try the comp with out the ups, which I have and nothing different.
Any help would be immensely appreciated. Spending this much on a new machine and having an issue that I have no idea what's causing it is driving me nuts!
My set up:
Intel Core i7-3770K
Asus SABERTOOTH Z77
