- Mar 27, 2013
- Ruakaka, Northland, NewZealand
So my old computer was locked at 2.5 ghz because of "Chassis intruded Fatal error" I tryed everything but i couldn't Fix it.
p5kpl-cm mobo
Intel e5200 Dualcore 2.5ghz
2 GB Corsair ddr2 ram
PSU 650 Corsair
HIS ICEQ X 6850 HD
Because of the Chassis problem i decided to upgrade and i went with
GIGABYTE GA-970A-D3 AMD970 SB950 AM3+ DDR3 PCI-E
CPU AMD FX 8350 8 CORE 4.0 ghz
DDR3 2x4 GB Corsair
ASUS DVD writer
Same GPU 6850
I have my CPU overclocked to 4.2 ghz just by changing the BCLK CLOCK CONTROL from 200.00 mhz to 210.00 mhz, The DRAM voltage was set and stock 1.5V so i turned it down to 1.329V (I hope thats ok?)
I have my HIS iceq X 6850 overclocked using AMD vision engine controll.
Im just wondering if there is other settings that i need to change?.. Also-
The other night i was playing Counter Strike Source and my FPS was constant between 950-1050 (Which was a first and was INSANE!)
I'm not sure how i did it??? :S But now it is back to what it was before....
I'm wondering if it would be Something i set with my GPU or CPU to get it constant or if it was the dx level i set in my Launch options
(I don't think it was my dx level, Because it didn't change on the next restart and playing the game)
Any help with Getting my FPS back to constant 950 or more would be awesome !!
Also,
I'm just wondering if any of you could help me find my stable limit for my GPU, And if my CPU is alright at 4.2 ghz Over Clocked?
Temp for GPU Doesn't rise over 60 so far when i had it near max Overclock and CPU temp doesn't rise over 50 with the 4.2 overclock and with stock cooler While in games, I have a EVO212 Cooler master Heat sink available to use if i need it ;D
I know its only a standard overclock and setup but from my old computer it is a HUGE upgrade lol and its awesome LOL.
P.S I'm Sorry if this is in the wrong section or for any typo's
Any help would be MUCH appreciated ^
p5kpl-cm mobo
PSU 650 Corsair
HIS ICEQ X 6850 HD
DDR3 2x4 GB Corsair
ASUS DVD writer
Same GPU 6850
Also,
