- Nov 21, 2018
So I just picked up a Hydro X loop and I must say I like it. CPU block has a few non functional LED's so I get to take that back this weekend and exchange it. But the block cools a Ryzen 9 really good.
Like the new what I guess is transparent nylon. From what I hear it won't turn color. Sucks that the rgb needs the commander pro. But it's proper RGB not like ek's
Big fan of the mounting . I really like how easy it is to swap out the mounts and rotate the mounting.
Pump this is my first D5 and it's pretty loud. I gotta adjust the pwm on it. For the radiator I got the big thick 240. This is a CPU loop only and wow that Ryzen heats it up. All I can fit in there for the cpu is a 240. So I went with the thick one. Over all not bad stuff and it's not priced bad at all.
I might pick up a commander pro. But I really wanted to try out this new plastic. Definitely feels like cracking won't be an issue. The stuff is definitely worth a look.
Just weird going from a ddc to a d5. I just gotta get that pump dialed in because it's driving me nuts. Different sound then my ddc
