- Jun 9, 2002
- Thread Starter
- #141
Thought it sounded like cough medicine.
3.4v is good for 265Mhz, down from the initial 3.5v that was required. I believe you're likely to recieve errors with numerous memtest runs if you fail to actively cool the dimms as well as the vdimm regulator under the heatsink by the memory.
Timings are:
1.5-2-2-7-15. The most crucial discoveries I've made with regards to timings is that the default Tref value(3120) isn't stable over 260Mhz for me. Changing it to 0648 allowed for more speed. I experimented briefly with [email protected] and I believe I can stabilize there, but alas my CPU gives up the ghost before 2.7Ghz. I suppose I should drop the CPU multi and try some higher memory speeds, but I believe I'll wait for the bios savior that's on the way. Which leads me to cautioning you in this regard. Please be careful with memory timings on this board. On two occasions now I've caused it to become unable to post and it took me several hours to get it back. Make sure you've read the well written sticky on avoiding bios corruption in the DFI MB section here as well as the post by angry games on how to properly flash the bios on the DFI. If the board has a weakness it is being easily suseptible to bios corruption, which as you may well know has been an ongoing problem with DFI for some time. I've never had to RMA a DFI board despite this problem though, a little caution and patience goes a long way. Just the same if you're planning to keep the board for a long time and push it hard(duh ) then a bios savior kit will likely be a good choice. eva2000 confirmed that the RD1-PMC4 kit works on the DFI nF4 boards and I have an RD1-8X on order that's almost certain to work.
Timings are:
